Kenwood NX5200 & NX5700 Self-Testing
firemedic834
Working on a radio project. The departments have purchased NX-5200s and NX-5700s with the AE31K encryption module and the 5100CV P25 conventional option. There is a 20 second self-test completed after powering the radios on. Using other Kenwood radios, the self-test is much shorter at 5 seconds. What is causing the lengthy self-test? There is no encryption programmed at the moment, so is the software searching for the encryption and causing the delay? Is there another cause?
kd4efm
Florida
If the board is installed, yes.
Without the board, even though SCM is checked, it will sense no board and continue bootup.
With the board it check integrity.
firemedic834
I’m not clear on your answer. Can you break it down for me?
AM909
Radio/computer geek
SoCal
I have 5300 and 5800 with AE31K that are not currently in use (i.e. there are no keys loaded) and they don't exhibit this problem.
AM909
Radio/computer geek
SoCal
I know NX-5300 doesn't do that with an AE31K that has no keys in it (at least one that was recently here that had yet to be keyloaded), regardless of whether there are channels programmed as secure or not.
Bluetooth and GPS come to mind. Is Bluetooth maybe looking to connect to something? Is GPS looking for a signal and the radio maybe configured in some way to wait for that to send a location squawk, before allowing user mode? You may be able to disable either or both through the menu on the radio. These radios are highly-configurable, so it's hard to say exactly how to go about hunting down the culprit.
Do you have KPG-D1N software or did your dealer program them?
firemedic834
Alright, those seem like plausible options to check. I do have the KPG-D1N software.
KK6ZTE
California
I've seen this after a radio got zeroized due to the battery going dead and not have infinite key retention enabled. Configure the radio properly and you shouldn't have an issue.
firemedic834
Winner winner chicken dinner! Enabling the infinite key fixed it. Power on the radio now, self-testing is gone, and able to use the radio 20 seconds sooner. Thank you.
