Kenwood NX5700 program software
nbfd23
Can someone help me out I am looking for the software that I need to install on my computer to be able to enter the code key. I was told to download it from Kenwood's website but I am not able to find it, also any recommendations for a cable to purchase to hook my computer to the mobile radio to program it?
AM909
Radio/computer geek
SoCal
The programming software is KPG-D1N and it comes with the license manager, KPT-300LMC. But yeah, you'll probably need the help of a dealer or someone who's done it to get everything installed and working and use it – some of it is not very intuitive.
nbfd23
Ok thank you very much for the help
fontanei
Redondo Beach, CA
nbfd23,
I just went through this...
You will need:
1. KPG-D1N_V510 software (radio programming software)
2. KPT-300LMC_V201 (kenwood's License Management Client)
3. Install #2 and then #1.
4. Open #2 and you will drag and drop the license file for the KPG-D1N_V510 authentication: DEALER_KPG-D1N_W_xxxxx.jkefs. The 'W' means the entitlement to program wide FM frequencies such as for AMATEUR RADIO. I cannot remember the exact procedure. There are a lot of youtube videos on this. There is a series by specialty communications. At this point you can start programming your radio; however, you will NOT be able to 'activate' entitlements/features for which you bought licenses for until you complete step 5.
5. Once you are done with #4, you HAVE to authenticate/create 'your account' with Kenwood if you wish to add entitlements/features to your radio(s). To do this, you drag and drop: KWD-ACT___xxx.jkefa into the KPT-300LMC_V201. Again, I cannot remember the exact procedure although I just did this last night. Go look al specialty communication's youtube videos.
If anyone else wants to correct my write up please do so. I'd hate for other people to go through the same struggle I went through.
Only thing I'd add is that the NX series radios don't need a W license to do wide band on VHF below 150.1MHz. At least none of our NX-5700's or 5200's have (or NX-210s, NX-700's, NX3200's)
If you need wideband above 150.1MHz (marine VHF), or on any part of the UHF band (including GMRS or amateur), you -do- need the W license.
Reelfishguy
If you download the KPGD1N from Dealer Tools, it has the KPGD1N, KFL, and the version 1 of the LMC. So you have to download the version 2 of the LMC from Dealer Tools in order for everything to work.
