Kenwood TK-2180 portable : can a codeplug be written from another TK-2180 radio?
g8tzl2004
Is it possible to write a "fully populated" codeplug from an identical TK-2180 portable to another identical TK-2180 portable?
If its possible, is there any risk of copying the alignment data from the other radio?
Is it also possible to copy the codeplug data from a TK-7180 mobile to a TK-2180 portable?
Arizona
Yes you can copy all your data over between them, your tuning data will not transfer over. Yes you can transfer between the 2180 and 7180 but it will warn you about button assignments being cleared.
Also, if you are using and Fleetsync, or MDC1200 those ID's will transfer over as well. So if you are needing each radio to have different ID's then you will need to change those after.
g8tzl2004
Many thanks fire-master_21
Is it possible to write a codeplug from a digital NX-720 (programmed with only analog data) to a TK-2180?
AM909
Radio/computer geek
SoCal
Software for both radios has import/export functions that can help with some of the transfer, though you'll likely need to check/edit the result somewhat, but it can at least make moving a large number of analog channels over.
