Kenwood TK-250 two tone encode
Andrew402
I was wondering if my Kenwood TK-250 can send out two tone page's to test my fire dept's pager's..
-Andrew
ko6jw_2
Santa Ynez, CA
Not unless your dept. uses DTMF paging. There are many different paging systems. Do you know which one you're using. My local dept. uses GE paging tones.
ko6jw_2
Santa Ynez, CA
These radios have some tone signaling capabilities, but the radio must be programmed for them. Kenwood had many different options. You would need to know the type of paging codes you use and if they can be programmed into this radio. This is an older model. Kenwood doesn't have the manual for it in their web site anymore.
Andrew402
Okay, I have it figured out.. My next question is can you have more than 1 set tone tone's set for the same freq?
ko6jw_2
Santa Ynez, CA
I believe that you can, but I am now beyond the limits of my knowledge of the TK-250. There is a selective call feature that may do what you want.
sfd119
Andrew402,
I have not played with a TK-250, but if it supports Quick Call II (the two tones), it should be able to do multi-tones.
Although, looking more into the radio, that looks pretty old and it might not be able to....
grp318
Yes you can, but not at the same time. Make two different channels with the same freq. set one 2tone for the first and the second 2tone for the second freq. the TK250 will not sent the tones orther than DTMF.
Andrew402
Also the radio only alert's when it's in not monitor mode.. Is their a way to get it to monitor when it is in monitor mode??
gewecke
Illinois
Yes, but only if it's enabled in the software during programming ...
73,
n9zas
gewecke
Illinois
Can you tell me were in the software to go? I have not found it.
Sorry, I'm not familiar with the software for the TK250. I have it for the TK353 which is similar though. simply enabling the monitor switch on the radio should do it.
73,
n9zas
