Kenwood tk-270
jfpolacko
Beloit, Wisconsin
I got a Kenwood TK-270 that I just got and I'm fairly new to... My issue is that I can key up to transmit but no voice! But you can hear the thump if you tap on the mic.. Me and my buddy was trying to talk on a simplex channel but every time i go to transmit (No Voice) is there a setting that might be off? or does anyone have any ideas as to what that might be?
You may be close enough to the other radio to be completely overloading it. Try getting a few hundred feet apart and see what happens.
jfpolacko
Beloit, Wisconsin
That don't explain why we can't talk on a repeater? I can transmit but no voice but we can hear tap tap tap when we tap the mic bot built in and plugged in....
It does depending on the input and output offset. A strong radio signal, even if not on the same frequency, can overload the front end of the receiver.
Other things to look at would be if the radio is really transmitting on frequency or not. TK270's have been around for a while. Could be that it's in need of a tune up.
jfpolacko
Beloit, Wisconsin
Okay makes more sense.... I'll have to take it to someone that can tune it up... on another note i got these instructions for field programming
Press and hold (light) & (dial) while turning on radio.
Hold until (SEL) appears on the display.
Pressing (SCN) allows you to program the following
1. Monitor Key
Off = off
1 = Monitor momentary
2 = Monitor Lock
3 = Squelch off momentary
2. Scan Key
Off = off
Co = carrier operate
To = Time operate
3. Dial Key
Off = off
On = enable
4. TA key
TA = talkaround
RV = Reverse
Off
5. Lo Key
On
Off
6. Priority
None
1 = fixed
2 = selected
7. Fixed Priority Channel
Turn selector to channel
8. Look back time A
Turn selector to time in seconds
9. Look back time B
10. Revert Channel
1 = Selected
2 = Last Call
3 = Last used
4 = Selected + Talkback
5 = Priority
6 = Priority + Talkback
11. Tx Dwell time
12. Drop out delay
13. Time out timer
14. Tot Pre-alert
15. Tot Rekey time
16. Tot reset time
17. Squelch Level
Turn selector to Squelch
18. Beep tone
On
Off
19. Signalling
And
Or
20. Battery Save
On
Off
21. Selectable QT
On
Off
22. Clr to transpond
On
Off
23. Del/ Add
On
Off
Pressing (Dial) allows programming of:
DTMF
24. digit time
Turn selector to time in milliseconds
25. inter digit time
26. First digit time
27. Rise time
28. Rise time with QT
29. PTT ID
Off
1 = connect
2 = disconnect
3 = Both
30. Dial ID
On
Off
31. Connect ID
32. Disconnect ID
33. # of DTMF keys on Keypad
12
16
34. DTMF hold time
On
Off
35. Store & send
On
Off
36. D key assignment
Turn selector to D or time in seconds for pause
37. Dtmf Signaling
Off
1 = code squelch
2 = Selective Call
38. Intermediate Code
OFF
A
B
C
D
E
F
39. Group Code
OFF
A
B
C
D
E
F
40. Auto Reset time
Turn selector for time in Seconds
41. Call Alert/ Transpond
Off
1 =
2 =
3
4
5
42. Transpond
On
Off
Pressing (TA) will allow you to program Frequencies
Use selector to choose channel
Press PTT
Enter Rx frequency using:
- the Selector Knob to change kHz;
- the Selector Knob + (light) to change MHz.
If no channel is Shown press the (LO) button.
Press PTT
Enter Rx CTCSS code
Press PTT
Enter Tx Frequency as above
Press PTT
Enter Tx CTCSS code
Press PTT
1. Option Signal
Off
1 = DTMF
2 = 2-Tone
2. PTT ID
On
Off
3. Add/ Del
4. Busy Tx
5. Clock frequency shift
6. Power
Hi
Low
can anyone walk me thru some of these instructions
speedwaysafety
Roseburg, Oregon
1. Monitor Key
Off = off
1 = Monitor momentary means that it will open squelch while you hold the monitor button if it is set
up to open with a tone like a minitor pager
2 = Monitor Lock open squelch and leave it open till you push the button again
3 = Squelch off momentary basically the same function as 1
2. Scan Key
Off = off
Co = carrier operate locks on ch until the carrier closes then resumes scanning
To = Time operate stays on ch for determined set time in secs set up down further in the list
3. Dial Key
Off = off this is if you have a interconnect system for ph calls or to call another radio if it requires a tone to open the squelch
On = enable
4. TA key
TA = talkaround if you have a repeater and a direct channel you can use this rather than programming 2 chs if it is set for TA when pushed you will tx on the rx channel
RV = Reverse Set for RV you will TX and RX on the TX channel
Off
5. Lo Key
On tx power if you set a ch to transmit on Hi you can temporaly tx on Lo
Off
6. Priority
None
1 = fixed Fixed is determined in initial programming of your freqs or you can set it as selected so that whatever ch your selector is on is the priority ch
2 = selected
Turn selector to channel this is if you have step 6 set for fixed priority
8. Look back time A steps 8 and 9 are for the look back times when scanning for the priority channel
9. Look back time B
10. Revert Channel (similar to a home channel or while scanning if you transmit and it goes back to scanning when you key up again this is what channel it would go back to)
1 = Selected
2 = Last Call
3 = Last used
5 = Priority
11. Tx Dwell time steps 11-16 I haven't messed with ask an expert lol
12. Drop out delay
13. Time out timer
14. Tot Pre-alert
15. Tot Rekey time
16. Tot reset time
17. Squelch Level this is the overall squelch level for the radio 0-9 is the level options I believe
18. Beep tone
On
Off
19. Signalling
And
Or
20. Battery Save
On
Off
21. Selectable QT
On
Off
On
Off
23. Del/ Add this to add or delete what chs you want in your scan with it off all chs are scanned with it on you can later go through and select individual chs to scan
On
Off
Pressing (Dial) allows programming of: this goes back to the earlier step for the interconnect and such
steps 24-42
DTMF
24. digit time
27. Rise time
29. PTT ID
Off
1 = connect
2 = disconnect
3 = Both
30. Dial ID
On
Off
31. Connect ID
32. Disconnect ID
12
16
34. DTMF hold time
On
Off
35. Store & send
On
Off
37. Dtmf Signaling
Off
1 = code squelch
2 = Selective Call
OFF
A
B
C
D
E
F
39. Group Code
OFF
A
B
C
D
E
F
40. Auto Reset time
Off
1 =
2 =
3
4
5
42. Transpond
On
Off
Press PTT
Press PTT
Enter Rx CTCSS code if there is no tone showing press the (LO) and then use the ch selector knob to cycle through the tones
Press PTT
Enter Tx Frequency as above if your rx/tx is the same press (LO) and it will come up
Press PTT
Enter Tx CTCSS code
Press PTT
1. Option Signal ?? havent messed with
Off
1 = DTMF
2 = 2-Tone
2. PTT ID ?? havent messed with
On
Off
3. Add/ Del this is where you can now chose if you want the ch in scan
4. Busy Tx tx lock out if the ch is busy you can not tx
5. Clock frequency shift ?? havent messed with
6. Power
Hi
Low
hope this helps probably clear as mud right lol I use TK270's almost exclusively got several of mine from fire guys over the years off of ebay
