Kenwood TK-280
DTFAudio
Matthews, NC
I recently picked up a Kenwood TK-280 to use for my local VFD. I need some programming info / how-to for this radio.... Any help is appreciated.
Thanks,
DTFAudio
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
You have to contact a Kenwood dealer, and purchase the software. You will also need a programming cable, it is your choice as to buying an actual Kenwood cable or one from China. (The Chinese ones are all over Ebay.)
DTFAudio
Matthews, NC
Ok. How much does the software usually run?
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
I got an aftermarket cable from a guy off ebay from Idaho, it is a usb cable and it has been flawless for my TK280. The windows software is EASY to use, and works very well. When you get the software and cable remember to DOWNLOAD and save the radio data in a safe place before doing any changes.
krokus
I don't know the price for the software. Contact a Kenwood dealer.
DTFAudio
Matthews, NC
Thanks for the help guys. Just to double check, I can use a Kenwood VHF Radio to monitor analog channels and talk correct?
kayn1n32008
ØÆSØ
Sector 001
Yup, just make sure you have authorization to talk. Clear it with your chief before talking on the radio. It will work analog only, conventional and LTR trunk systems
DTFAudio
Matthews, NC
Thanks for info guys! I'll order the software on Monday from Kenwood and get a programming cable off Ebay as well. Radio should be here by Wednesday.
DTFAudio
Matthews, NC
I ended up getting a TK-270G. I have a few other questions-
1. This radio is field programmable is what I have been told, is this true?
2. When I enter the freq's that I want are there separate freq's that I need to use in order to talk / transmit? For example if I plug in 154.22000 for a VFD, will I be able to talk over the same freq as well?
3. Can I disable the PTT function on this radio?
4. Can I spell out a word in the display instead of channels? So, can I replace channel 1 with "Fire"?
Thanks,
DTFAudio
ramal121
Lots and lots of watts
Calif Whine Country
Thanks,
DTFAudio
1. Yes, IF that option is enabled in software programming. Cumbersome but works.
2. You will need to enter the receive and transmit frequencies separately. For a direct channel, both
the receive and transmit are the same. For a repeater you'll need the correct transmit frequency
which will be different.
3. Just leave the transmit frequency blank. No PTT will be possible on that channel.
4. Yes. A maximum of 8 characters possible.
DTFAudio
Matthews, NC
Thanks for the info! Last thing, where do I find the transmit frequencies? Couldn't seem to track them down in the database....
