Kenwood TK-3000
ANYNETWORK2484
I have a legal copy of the KPG-137D software, however it only lists the K model, the radio I need to program has the letter M on the box, when trying to program, I am getting an error "wrong" model. Any suggestion as to where I can get the software which supports this M series? Thanking you in advance!
Larry M (810) 986-0945
WB5UOM
'K' denotes US version
you will have to dig to find s/w for the M version made for across the pond
"M" market code is "Other Areas" in Kenwood land.
L = Scandinavia
K = USA
P = Canada
Y = Far East
T = England
E = Europe
C = China
X = Australia
KPG-137D is the correct software for the TK-x000 line of radios.
However, the TK-2000/3000 were never sold in the USA, as far as I can tell. That jives with the "M" market code. The trick with Kenwood software is that the KPG software has to be activated with the correct market code serial number to match the radio. That way the software knows what parameters the radio is requires to run under to be legal in the country in which it is used. If you "found" the software under some internet rock somewhere and activated it with some random serial number found under some internet rock somewhere, then it's likely the software key doesn't match the market code of the radio.
The solution to this is to redo your software installation and make sure you find an activation serial number that is for the M market code. That'll serial number should look something like: 137M4#######XXXX
And, I agree with above. If you bought this radio off e-Bay, see if you can get your money back. Finding the correct software serial number might be easy, might be impossible. Also, the radio likely does not have FCC type certification for legal use on anything other than the amateur radio bands.
ANYNETWORK2484
Thank everyone for the excellent support! If anyone knows a site in India or anywhere I can purchase the necessary S/N for the M radio, I would be forever thankful!
73
Larry
K8NYY
