Kenwood TK-3140 programming query
paulears
Lowestoft - UK
Hi, I have a batch of these radios and programmed them all up for a job, using a previous .dat file and changing some details, and somewhere along the way, I have changed something that's messed up the operation.
It's fairly simple - two simplex and one duplex channel, and the only requirement is that the callers radio ID (running from 4001 to 4033) comes up on every radio. I thought I'd sorted it out, programming the 'A' key to switch into ID number mode - but this simply gives access to all the individual IDs that are in one of the programming lists. Does anyone have an old .dat file (codeplug) that has these features in that I can use as a new starting point. I hear the data burst when the PTT is pressed, but none of the radios seems able to display it.
It's probably going to be just one box that has the wrong info in it - but I simply cannot remember what I did last time. If anyone can help - or from memory suggest checking X or Y parameters, It would be a real help.
Paul
ohiohonda
It sounds like you are using fleetsync. To be able to show this on the receiving radio you would need to enable caller Id display. This feature is in the fleetsync tab. Each radio would have the same fleet own number but a unique ID number under the same fleetsync window. If you only want it to display the 4 digit number on the caller ID display, you would need to setup the Id list table.
paulears
Lowestoft - UK
I've got the ID List table setup, but and I've managed to activate accidentally some kind of response situation. Pressing the PTT on radio 4008 puts it into TX, but unless one of the other radios has had it's PTT pressed, 4008's audio doesn't come out of any of the others. Pressing any radio's PTT sort of enables 4008's ability to send audio. IDs do not appear on the display - yet, however, the selcall features seems to work - I programmed the S button to change the display to selcall, and rotating the dial on unit 4008 to read say 4013 and then pressing the PTT makes radio 4013 display 4008 in it's display. BUT - 4008 again has no audio until 4013 gives a quick burst on the PTT. I've changed so many parameters, I've messed everything up. Maybe I should find one of the old very simple files and start again? I suspect it's just a case of an unwanted tick in a box, but I cannot find it.
EDIT
I just noticed that my 320's when set to the analogue channel the 3140s are on - reads the data burst and displays the correct group and unit ID - so they are sending it, but I cannot get them to display it! Weird!
ohiohonda
I would check in the optional features 1 tab that signaling is not set for the AND option. If AND is set the radio will not unmute until the radio receives the correct frequency, DPL or PL , and the optional signaling(which would be the fleet sync number of the radio).
