paulears
Hi, I have a batch of these radios and programmed them all up for a job, using a previous .dat file and changing some details, and somewhere along the way, I have changed something that's messed up the operation.
It's fairly simple - two simplex and one duplex channel, and the only requirement is that the callers radio ID (running from 4001 to 4033) comes up on every radio. I thought I'd sorted it out, programming the 'A' key to switch into ID number mode - but this simply gives access to all the individual IDs that are in one of the programming lists. Does anyone have an old .dat file (codeplug) that has these features in that I can use as a new starting point. I hear the data burst when the PTT is pressed, but none of the radios seems able to display it.
It's probably going to be just one box that has the wrong info in it - but I simply cannot remember what I did last time. If anyone can help - or from memory suggest checking X or Y parameters, It would be a real help.
Paul
Paul
