Kenwood TK-3402U16P
lamboman316
When I turn on I get a solid green light, I can transmit, but can't receive. I did a factory reset and programmed using the software, same results. Any Idea??
cmdrwill
So Cali
The radio should have been read first with the proper programming software. Then that 'codeplug' archived, saved, to a safe place.
The Golden Rule of Programming.
Now you do not have anything to go back to.
And a "factory reset", your radio could loose all alignment and calibration values.
lamboman316
It wasn't working correctly before reading it, and resetting it, so the codeplug would not of made a difference if I saved it. Its configured like my other radios , so must be something wrong with the unit, I guess
lamboman316
Solid green LED means it's receiving.
Might be the squelch out of adjustment.
squelch out of adjusting as in internal? the setting is the same as my other 3402. must be something wrong with it I guess, not worth fixing
