kenwood tk-350G (cant read/write)
n8phl
Zanesville, Ohio
have a 350G that even with the kpg-22/kpg-23d I cant read or write to.
the setup is as follows.
368 sx25 running pure dos ver. 5.
kpg-23d/kpg-22.
when i try to read sometimes i get check connections error.
other times I get check radio model type error.
to place the radio in to programming mode i press and hold the light & scan buttons while i turn the radio on.
it displays "PROG" and flashes "PROG".
any idea what i am doing wrong?
gewecke
Banned
Illinois
I haven't used the software to program the 350, BUT did you know that you CAN program that without the software?
Here's a link to programming the 350 by hand,with other info as well,
http://www.notpurfect.com/main/tk350.html
73,
n9zas
obijohn
You are putting the radio in the wrong programming mode. The "PROG" mode is for updating the firmware. You need to put the radio in the "PC" mode. Unfortunatly, I don't have my '350 here to
refresh my memory which button sequence to push. Lamp and the far right top button?
