Kenwood tk-5210 question
Wrench1
I have a ver 1 tk-5210 and I see that I will not let you encode 2-tone only decode. But I see that the ver 2 radios will let it encode. Is there a way to get a ver 1 radio to encode 2-tone?
Wrench1
Update
I have more information to add and need to ask another question. So I am not able to get the radio to read. When I go to read the radio I get the check connection message. But I can read the radio information useing tools. So if i can read the information out of the radio and get serial number firmware info and all that I dont get why I can't read the radio to program.
Wrench1
I have used both KPG-95D v6.21 and KPG-95DG
Both of them will let me read the radio information in the tools tab. Serial number and stuff. But both of them wont let me read the radio. So I thought I would see if I could load some channels into the radio. I made so I just put the weather channels into the program. With KPG-95DG it gave me a check radio type and firmware and would not let me write to the radio. Now with KPG-95D I was able to load the weather channels to the radio. I then tried to read the radio and it again gave me the check connection message. So I can write but I can't read?
code3cowboy
CA-CZU
Are you using an OEM or aftermarket cable?
Is the radio password protected?
Is the battery charged?
What is your setup for programming?
Wrench1
I am using an aftermarket USB cable. Note that I have never had any problems with the cable to read 3180-280-480-2180
I dont think that the radio is password protected but how can you tell with out being able to read the radio?
The battery has a full charge.
I have used my CF-29 toughbook with XP do all of my programming off it with no problems. Also tried my my dell with Win7.
The part that I dont under stand is why can i read the Transceiver with tools and it will give me the radio serial and all that. But yet i cant read the programming?
n3obl
Ø
PA
I would see if you have access to an OEM cable. Some of the aftermarket cables can be funny with certain radios.
Wrench1
I will do some checking around and see if I can get my hands on another cable.
Wrench1
Problem fixed. Updated firmware and now I have no problems reading the radio. Still the same cable I started with.
