Kenwood Tk-5210 scan bank issue
Baker845
radio's aren't toys.
Oregon
I have Kenwood Tk-5210, and when switch between zones, the radio picks up traffic on channels not in my scan list. Is there setting in programming i can fix this?
I looked everywhere and haven't had any luck fixing this issue.
kd4efm
EL98 Florida
you have screenshots of your code plug to show your settings
Baker845
Oregon
I have scan type set it conventional single zone. That is the only thing i set. Would changing it to just conventional zone fix the channels not in scan list from stopping?
kd4efm
EL98 Florida
It would be worth testing that. Without being able to test your codeplug (sold the 5210 at the orlando hamfest)
ramal121
Lots and lots of watts
Calif Whine Country
Scan in this model has always befuddled me but I guess I haven't spent the time to get it all straight. So I will throw this out but may not be 100% correct.
You can create up to 16 different scan lists. Scan lists are only used when Conventional scan is selected. Scan lists are assigned to personalities, not zones. They cannot be modified by the user. I really avoid scan lists.
If you use Conventional Single or Conventional Multi as a scan type then the scan list is ignored (if you have one filled out). Scan channels are dictated by the scan add colunm in the Zone/Channel Parameters window. Using either scan type allows you to program a button to add/delete scan members (and zones) on the fly. My preferred method.
I do have a 5210 somewhere that hasn't been sold yet but that's because I not sure where it is. If need be I could dig for it to test with.
