Kenwood TK-5220/5320 Pop 25
esfd283
Hello All, Looking for some guidance from the Kenwood experts on board here. Our county has a Motorola P25 digital trunked system. They want to begin to allow radios other than Motorola's on to it, can anyone tell me how the Motorola system information is entered into the radio. I know the Motorola radios have to have a system key associated with it for programming. Is that the case with the Kenwood's? Any help is greatly appreciated.
pddispatcher
If its not encrypted or anything and its regular P-25 all you should need is just the RX/TX and NAC
RKG
Boston, MA
"System key" refers to trunking. Kenwood does not make a radio that will work with a Motorola Astro 25 9600 baud trunked system.
If you're talking conventional, you do as pddispatcher said.
esfd283
Interesting as the sales people in this area are trying to sell that. Wasn't Project 25 supposed to fix all of this???
monitor142
California
P25 is a suite of standards mostly surrounding the Common Air Interface (CAI). P25 is both conventional and also trunked. I believe that some of Kenwood's P25 equipment is only conventional at this time.
As a prime example, you have Los Angeles PD as a P25 conventional system and the State of Michigan or Illinois Starcom21 as P25 trunked systems.
-M142
w2csx
Rochester,NY
esfd283, seeing how you are in Onondaga County, NY, the Kenwood UHF P25 radios won't work cause they use trunked UHF system. EF Johnson will work though and am not sure but I think they are the only other radio that will work with Motorola Trunk system cause in parts EF Johnson is Motorola due to government contracts.
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
You may want to check the kenwood stuff again it may not work on an ASTRO 25 trunk system but I think (don't have my computer in front of me right now) kenwood P25 will do 9600baud P25 trunking. You may want to check the specs on the kenwood gear.
amradioguy2
Minnesota Area
Kenwood Radios on P25 Trunked Systems
Kenwood does make radios that will work on P-25 CAI Trunked systems.
The model TK-5910 Mobile and the TK-5410 Portable have been tested and approved on the Minnesota ARMER System.
kayn1n32008
ØÆSØ
Sector 001
Looked at kenwoods website and for these particular radios 9600 P25 is a 'future' option, my bad, I was thinking of the model posted by the above person
kenjicam
Pasadena,CA
Yes Kenwood P25 trunk radios will work on a P25 trunk radio system. However, you will need all the stuff that a Motorola radio would need to work on the system programmed into it. A system key (from Kenwood), frequency information ,talk group information, encryption keys( a KVL with proper adapter cable for Kenwood radios ) if used on your talk groups,and someone to program all that stuff for you.
n3obl
Ø
PA
One thing that some motorola 9600 trunk systems use is ADP software encryption. Its a cheap way to encrypt a talkgroup. Downside is you need to have motorola radios to support it as the other brands cant support it.
Astro25
Chicagoland
Kenwood's current line-up of P25 products WILL trunk... the only drawback is the lower-tier P25 products (ie TK-5220) will only support one TRS per radio, where the high-teir P25 products (ie TK-5210G) will support multiple systems. We already have set a number of 5210G units on the WISCOM state-wide system.
kenjicam
Pasadena,CA
We've been field testing the TK5310 portable (also the 5320, 5810, and 5820) on the new local UHF P25 system for the past few weeks, and they have all been preforming very well. The biggest problem has been trying to convince the different agencies that Motorola isn't the only choice for subscriber units.
