Kenwood TK-5270
imathesonksc
Greetings,
First time posting. Our agency has two tk-5720 in our cruisers. Since the past summer, the units have been resetting themselves (power down and back on), at random times. They have been sent back to Kenwood and "reprogrammed" with no success several times.
Is anyone else having this issue or has any thoughts?
n3obl
ØAES-1056
PA
Need to check the power connections to the radio. Are they connected directly to battery or through a power distribution center.
imathesonksc
So we had our local repair shop take it and they had it in their truck, did the same thing for them. Wiring in the mobile radio or wiring in the actual vehicle?
Did someone program ignition sense?
Check the fuse on the radio power lead, they are a common point of failure.
wd8chl
Seconded. Check for ignition sense in programming, and if so, check the yellow lead for proper ignition voltage. Easiest way to check-take the yellow lead and if it's not connected, run it to +12 somehow-only needs a few dozen mA. If it comes on after a few seconds, that's it. Wire it to a source, however you want to have the radio switched.
Echo4Thirty
Colorado Springs, CO
Low voltage and/or current will also cause this on TX. Make sure you have 13.8 and plenty of amperage to power the radio on transmit.
