Kenwood TK-5310 Error
Skymedic
North Central Mass
Howdy.
I have been trying to program my TK-5310. The KPG-95dj v7.01 software will read from the radio, but it will not write back to the radio. The following error comes up:
An error (s) has been detetcted in the following entry.
"Data System-Personality"
There is no problem when reading/writing from an earlier version of the software (v5.41 I think-it is a friends software not mine).
Any ideas?
Thanks in advance,
David
ramal121
Lots and lots of watts
Calif Whine Country
That is a user programming error. Kinda like setting a home channel button to a channel that doesn't exist.
You'll have to poke around in personalities to see if there is anything that doesn't jive.
What I don't know is why the difference between older and newer software. The newer FPU may have added feature sets and for some reason doesn't like how the older programming is laid out. A firmware upgrade may help.
Skymedic
North Central Mass
Re: Error
Thanks for the response.
I did poke around all the personalties, and nothing seems to be amiss. Took a while too-there are 392 channels. I wiped the radio clean, and re-installed the program using the old software. Again, no issues reading/writing with the earlier version, but the new version will only read, not write. Same error code comes up...
I will try and do a firmware update and see if that makes a difference...
evfd1625
Indiana
Check your zone information and all your tabs, make sure that a data channel isn't selected to something it shouldn't be. Sounds like a data system was enabled when you don't have a data system in the radio, If that makes sense. Just go through and disable data systems. I ran into this problem, except it said something about emergency personality, and it was set to fixed instead of selected, and the option was set to none with no channel information.
Skymedic
North Central Mass
I haven't actually had the time to get into the radio again and check out the data system workaround you suggested. I will post again when/if one of the solutions works...
