Kenwood TK-690/790/890 Firmware
michaelidoc
Illinois
I am probably beating a dead horse. I have a TK-690/790 and 890 and i want to upgrade the firmware. I cannot find out what the current firmware version is and i cannot find where to get any updated firmware for these radios. Any help? I tried HOLD FP1 on powerup and pressing MON but it is not showing the firmware.
KK6ZTE
California
Can you read and write them? Make sure "Firmware Version Information" (or similar) is checked under Optional Features or the button press won't work.
TK-x90 firmware versions are split by serial number. You'll need the serial numbers to get the correct firmware.
michaelidoc
Illinois
Yes i can read and write just fine. Just cant see the firmware version when i go into the front panel programming mode. I have enabled that cloning and other settings in the programming when i wrote to the radio. Im also having an issue with narrowband squelch. its even set to a 10-16 squelch level im still getting feedback. Gotchya on the firmware i guess ill just have to reach out to my local kenwood dealer. Was just trying to save a couple hundred in programming fees.
