Kenwood tk-7150 molex pin out
firefighter728
Kentucky
Hi, does anyone know the pin out diagram for the 6 pin molex connector on the back of the kenwood tk-7150. I'm trying to install the ignition sense cable but can't find which pin it should connect to. Thanks.
ramal121
Lots and lots of watts
Calif Whine Country
Yea, but it will cost you big time!
Looking at the back of the radio, at the 6pin molex;
Left pin column bottom to top, pins 1, 2, 3
Right pin column bottom to top, pins 4, 5, 6
Ignition sense is pin 1
Internal speaker - wire jumper in place pins 5 and 6
External speaker - remove jumper, speaker wires in pins 4 and 5
You don't really need ignition sense unless you are going to use horn alert or
timed power off. The radio will remember it's on/off state when the main power wire
is removed and reconnected.
ramal121
Calif Whine Country
Pins 2 and 3 are for speaker output "B"
This is used for auxillary speaker when public address is programmed in software and switches to these pins when PA button is pressed.
Bummer is you need option board for it to work...
Now the DB-25 connector is where the juicy stuff is...
