nah just for a local node so I could run it on low power for the house, are the 7180-8180 good mobiles ?
Thinking of putting separate vhf and uhf radios instead of a ham dual band in my truck . I have a 3180 that has now become my go to portable.
Lots of memories, great audio good alpha display and inexpensive software. I also just got a 5210 but have not done much with.
Yeah, I agree. Good radios.
The TK-7180/8180 use the same chassis as the NX-x00 series radios, so lots of accessories and support out there.
Programming is pretty straightforward, uses the same software as your TK-3180, in fact, you can port the same file over to the TK-8180 if it's the same bandsplit, with some minor button changes.
Get the KRK-10 remote head kit, and you can stuff these guys in small cars pretty easily.
I'm running a TK-7180H in my wifes truck. The small control head fit in well. The RF deck isn't big, about the size of a paperback book, so easy to tuck away.
The feature set is nice if all you need is analog. 512 channel capacity and the display will do up to 14 character channel names. Newer firmware will support MDC1200 if you want that. They'll all support FleetSync and DTMF signaling.
The DB-25 connector on the rear makes interfacing accessories really easy.
If you don't need the stuff that comes in a dual band radio, like built in cross band repeat, running a TK-7180 and a TK-8180 would be a good option. It's actually kind of nice having it as two separate radios.
