Kenwood TK-7180 Stuck in Remote CTRL Mode
Rt169Radio
CT
Hello, a Kenwood TK7180 I use has decided to throw a tantrum and stay stuck in remote ctrl mode. I believe a power switching from building power to generator power might have contributed to the start of this problem
Is there anything I can do to get it out of that mode or do I just have to take it too a commerical communications dealer to fix it?
I am a lineman for the county.
Is there anything plugged into the DB-25 on the back of the radio?
Only time they should show that is if they are programmed for the binary channel change function on the rear connector. If you don't have it programmed that way, then I suspect something went wonky when the power did it's little hoopty-doo.
