Kenwood TK-730 Priority
Asmitty0010
New Hampshire
Wondering how I can edit my Priority members in my scan list. In the programming software i've selected "Operator Selectable". Is there a way to select and edit your Priority via the control head? I know to delete/add a scan list member you have to hold "SCN and D/A". Didn't know if there was a button you have to press and hold for the priority members.
thanks for any help.
bhamfd19
Richmond, Maine
can you set your priority to selectable so then what ever channle you hit scan from will be you pirority. operator selectable depends on how you radio is set up, my dept radio is set up with it and i have to hold down the scan key.
vorndamr
Scanning
There are 3 settings. Fixed - which means you tell the sotware what channel you always want to be the 1st prioirty channem. Nest is Operable select - this means what ever channel you set it on before you start you scan is priority. Then there is 2nd priority which works the same as the 1st one. Rod
nmunger
Scan list delete not working for me
I tried holding scan and D/A to remove a channel from my scan list and it doesn't work.
What's the correct way to do this? I have a noisy channel that I don't want to scan for.
Thanks!
Nick
HummerMike
Abbeville, S.C.
Hit the scan button to take out of scan. go to the channel you want to delete from the list. Hold the scan button in while you hit the D/A button. You should see a little vertical tick appear and dissapear. If it is on, it's in the scan list. Off, not in scan.
nmunger
Works. I had to press the red button on the panel first to show the group and channel number, then scan and D/A took it off the scan list.
Thanks!!
