Kenwood TK-7360 HV-K no power
Mayberry831
Hello all!
Having some trouble with a Kendoow TK-7360 HV-K, has no power. Have checked fuses, checked that there is power and ground. Just like its not hooked up to power at all? Have two radios displaying same issue, sent one off to be repaired and they were unable to fix it, they replaced the power unit on the board, it did not fix. and help at all would be appreciated.
LATA 722
Is it set up for ignition sense power?
Try applying +12vdc to Pin 2 of the rear DB15 connector.
If it has KTC-60 cable attached, it's still pin 2 on the Molex cable.
