Kenwood TK-760G down banding.
KC9ZNV
Sauk County WI
Hi all, I am working with another ham to try and figure out if this public safety surplus radio can be down banded via software to work in the 144-148 Amatuer Radio 2 meter band.
The original seller claims it is 148-172 and he will program it for recieve only. Because he isnt licensed for the radios frequency range. Well. We aren't trying for those frequencies.
I have spent an hour on these forums looking but I don't always see a relation to which service its being used for.
So I decided to try it here. If a moderator decides to move this to the Amatuer radio forum that would be ok, but I found a thread where they moved one here so...
Sent from my SCH-R970 using Tapatalk
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Program away, if you are using the windows software. The software will warn you that the frequencies below 146MHz are out of band, but will allow the frequencies to be programmed.
I use one from low 144 to 173MHz no retuning.
Sent from my iPad using Tapatalk
KC9ZNV
Sauk County WI
So it is possible? I don't have the software.
I read on here places to download it but a product key is needed.
There are oodles of these old kenwoods around on the cheap so getting software and some cables may be worth while.
kayn1n32008
Sector 001
Very possible. I am using the software unmodified, and the radio has not been modified in any way.
bertedmund67
Hi there,
Would you know if the Kenwood TK-760H-1 is able to go down to 144MHZ? Would it be the same as described of the TK-760HG? Please advice. Thank you
kayn1n32008
Sector 001
Likely can be if it is a 148-174 model. Just enter frequencies. I have a TK-760HG-1 and it goes to 144MHz with out issue. I cant see the h-1 being any different.
bertedmund67
Kayn1n32008, thank you very much for the encouraging response. Will do as advised.
kayn1n32008
Sector 001
Although I have not used the h-1, try entering frequencies below 148. It may just warn you and let them stay. That's what the TK-760HG-1 does.
jaspence
Michigan
Out of band programmng
When ever you do this with a radio, it is a good idea to check the actual performance with test equipment. One radio on which I did a similar frequency shift showed a big drop in output and increase in current draw when I went below 146.000. It transmitted ok and received fine, but I doubt that it would have continued working well so far out of band.
kayn1n32008
Sector 001
Excellent advice! While I never had an issue with mine, would draw less than 10A(what it was fused for) @ 45w. The advice is sound.
bertedmund67
jaspence, this is exactly what I do not want to encounter when meddling outside the assigned band split. Any pointers that may remedies such disorder. Thanks
