Kenwood TK-760G UNPROG , PROG 576 problem
Roland33
Hello , i just got a Kenwood TK-760G , and initialy it had a problem , all characters from the lcd light up , after that i had re made some contacts with solder , and now its working but it shows on screen UNPROG , and it only responds to ON/OFF switch , initialy if i leave the unit off for couple of hours it will show up " PROG 576 " after that if i turn it off then on again it shows UNPROG , and its responding only to ON / OFF switch , nothing else .
"UNPROG" suggests that the radio does not have any programming loaded into it. Is this a new/old stock radio? Only responding to ON/OFF would support the idea that it's unprogrammed.
"PROG 576" means it's gone into firmware programming mode. That is usually accomplished by turning the radio on while pressing and holding ^ key.
