Kenwood TK-762HG-1 VHF 8 CH internal speaker audio
WQ1O
Hello to all.
I picked up a few Kenwwod TK-762HG-1 VHF mobiles (8ch type).
I'm using the KPG-56D programming software. It seems to program the frequencies fine.
I'm not getting any audio from the internal speakers of the 3 radios. It is fine if you plug in an external speaker. Is there something I need to reset (check or uncheck) in the software to get the internal speakers working, or is it a hardware jumper/switch?
Thanks for taking the time to read this
Frank
WQ1O
Yes, that was my first thought as well. I did check and they all are plugged in, cables looked good too.
NMO's installed, while-u-wait.
Do these radios have the multi-pin Molex type connector hanging out the back? If so, try pins 6 and 12 on the Molex connector. This is the setup for using the external KES-4 speaker.
If you just want to use the internal speaker, you can remove the KCT-19 cable and reconnect the internal speaker. The internal speaker would be connected to "CN8" on the TX/RX board. It's at the rear of the radio, right side when facing the front. It's right by the external speaker connection (1/8" jack)
WQ1O
After checking the cables....I tested the speakers. Looks like EVERY ONE of the speakers was blown......Since it was all three radios, I kind of doubted it. Sure enough, when I connected another speaker by clip leads, it was loud and clear.....Go figure....Thanks everyone for responding. I appreciate it.
