Hi all,
We just acquired a RoxiLink gateway device for RoIP via a Zello work gateway and plan to utilize some spare TK-790s with the gateways. I got everything installed and hooked up, but the radio will not trip when I key up on Zello. The gateway box clicks like it’s receiving a signal, but nothing from the radio.
So far, I did remove R641 and place a jumper on R640 for mic in/out rather than data, I programmed the rear function port for Ext PTT and COR (as the instructions stated, there are also many spots to select these in that particular menu, but I tried them all,) and I haven’t been able to get any audio to pass. Is anyone familiar with a setup similar, or any tricks for the 790s? I tried a radio that I hadn’t removed the jumper from just to see if the radio was bad, but that didn’t work either.
I should also add, the DB25 cable that attached the gateway to the radio was one that was supplied from RoxiTek, not a homemade cable.
