Kenwood TK-790 Tuning
Snakedoc84
Alright kenwood community I need some help. I know I have a tuning issue with my TK-790. When I transmit others can barely hear me. I'm looking for another TK-790 user to see if they can get into test mode of their radio and see what theirs is set for on each value, that way I can reference it to mine and maybe see where the problem lies. Or if anyone out there knows exactly which setting I need to chance and to what value. Any help with this issue would be appreciated. There are no kenwood techs or dealers in my area. Thanks all.
I am a lineman for the county.
You'd think that would work, but it probably won't. These settings are individual to each radio and vary depending on component tolerance variations. Copying these settings out of one radio and putting it in another would likely make the problem worse. If this isn't a simple programming issue (mic gain, wide/narrow) it really needs to be done with a proper service monitor. While it will cost a bit, the end result will be MUCH better.
Snakedoc84
Mmmckenna,
Ok we'll do you happen to know which setting that is in the tuning? I would like to be able to maybe do this myself if at all possible. I don't really want to have to send the radio off to kenwood then I would be dead in the water more so than I am now.
12dbsinad
Barely hear you as in very low TX audio, or a very scratchy/weak signal?
Could be your deviation is low, your TX is set to narrow and everyone else is RX'ing in wide, or any number of things. More information is needed.
Are you using this for commercial/LMR/Public Safety, or Amateur? Frequency? Is it happening on all channels, or just one/certain ones? There isn't just one setting that could be causing this issue, so you would need to tell us more….
Snakedoc84
The radio is used for public safety, First Responder / Firefighter. The radio is set on narrowband, and everyone else in our county is set for narrowband as well, so I wouldn't think that would be the issue, but then again I'm no expert. Gentleman, above all I would love to get this to a Kenwood dealer, problem is there are none in my area. I honestly don't know where the closest one is. I did a search on the Kenwood Website and it returned no results. Thanks.
Then this certainly sounds like an issue that requires a trip to a shop. Without knowing where you are, we can't help you much.
Since this is a radio that is used in a public safety roll, it isn't something I recommend doing on your own. A shop will fix the issue properly and make sure the radio is working correctly. All this requires some specific test equipment. While it'll cost you a bit, what you should get back is a perfectly functioning radio.
Post your location and maybe we can help you out.
ramal121
Lots and lots of watts
Calif Whine Country
Update to thread. Just had another tech call me - 790 with "no mic audio" The two of us banged our heads on the phone for a while. The radios were pulled from one department and passed on to another. The other tech said " well when the sheriff had them they had scramblers in them"! Ahah! that was it. If the radio has the optional scrambler board but it is not programmed for one, no mic audio. Receive audio is fine though. Easy enough to pull a cover and have a look...
