Kenwood TK-790H
DO5MP
KiLa,Germany
Hello, is there a way to get the Kenwood TK-790H to operate in the frequency range from 144 MHz using a modified firmware?
n7maq-1
Oregon
It should go to 144.00 with no problem as is. You might want to adjust the front end for better RX sensitivity.
mrweather
There is no need for modified firmware. The programming software will protest but accept frequencies below 148 MHz.
However, programming that low may put the radio out of lock (a repeated chirping when selecting the channel). In this case, you'll have to adjust the RX and TX VCO trimmers to bring it back into lock. Best to get a service manual for that task.
n3obl
ØAES-1024
PA
As posted above by retuning you will loose a little up in the 170 range. Would be beneficial to get a shop to throw on a service monitor and tune it. Also can check power output etc.
I have one or two I want to get retuned and serviced before using.
AM909
Radio/computer geek
SoCal
Which radio exactly? The US TK-790K is spec'd 148-174 MHz and the TK-790K2 is 136-156 MHz. I don't know if there were other markets (like E).
What software are you using? KPG-44D(K) v2.03 complains when you enter 146 in a 790K model, but then lets you proceed anyway.
DO5MP
KiLa,Germany
I have the US version from 148-174. I also want to program relays in DL.
I have version V2.10, the KPg-44d.
