Kenwood tk 8180 k does not turn on
DTilman
Humboldt, KS
Hey guys. I've got this non functioning tk8180 sitting here just being a paper weight. Before I pull the cover off and take a look under the hood of this thing. Does anyone have any suggestions on what might the problem be? And yes I hooked it to a power supply that I know works before I get any Jokers out there with that lol. They did cut the connector off from the radio I don't know why. But anything is appreciated thanks
Hiding in a coffee shop.
Apply + 12 volts to the Yellow ignition sense wire. If it's been set up for ignition sense, that should wake it up.
If that isn't it, then you'll need to open it up and start looking at it. There are internal fuses. Plugs can get disconnected, etc. Only way to know is to start looking.
DTilman
Humboldt, KS
Hey guys! I think I figured out the problem. It is a ribbon wire that connects the body of the unit to the head. it was just laying in the unit when I opened it up. Now my next question is where can you find these cables at? it had on the side of it AWM e41447-hcj 80c 60v 20624 VW1 can anyone decipher this for me? Where I might be able to find a replacement for it to see if that was the only problem?
