Kenwood TK-8180H-K2 power levels?
RenoHuskerDu
Longtime VFD, rusty old scanner
Bertram TX
I purchased a few of these in reserve a few years back. Now retired, I am deploying them. I got the first one programmed quite easily with the KPG-89DN software, which is a lot like a simplified CHIRP. The unit has very clean sound on Low power, running thru a Tram 1481.
I set all freqs to Low power for this testing phase. I pored thru the Kenwood manual and see no specs as to what power outputs are Low and High. A search here in RR was also unfruitful. Running in 460.nnn mhz, does anyone know what the Low level represents? I know High should be about 45w.
RenoHuskerDu
Bertram TX
Another curiosity is that other threads here mention that a narrowband TK-8180 can't run wideband. Not sure of the build date on mine, but its firmware is 1.22.00, and in KPG-89DN I can set each channel to wide or narrow. Perhaps that means it was built before 2012? When I set up the others, I'll learn more.
I am a lineman for the county.
I set all freqs to Low power for this testing phase. I pored thru the Kenwood manual and see no specs as to what power outputs are Low and High. A search here in RR was also unfruitful. Running in 460.nnn mhz, does anyone know what the High and Low levels represent?
TK-8180:
High Power = 30 watts
Low Power = 5 watts
TK-8180H:
High Power = 45 watts
Low Power = 10 watts
It's not the radio build date, it's the firmware version.
However, Kenwood did offer a wide band license for the KPG-89D software that would restore the capability to program wide band.
I've got a TK-3180 sitting next to me. The TK-2180/3180 uses the same firmware files and same programming software as the TK-7180/8180.
Mine is showing firmware 1.22, and it'll do wideband.
RenoHuskerDu
Bertram TX
Same thing I am seeing. I'm glad, as GMRS is 12.5k wide. Hope to QSO with friends who don't have ham.
GMRS is allowed to run 25KHz. Most repeaters are 25KHz. Most licensed GMRS users run 25KHz.
The FRS radios that share frequencies with GMRS are 12.5KHz.
If you run 12.5KHz, others running wide band GMRS may tell you your audio is low.
RenoHuskerDu
Bertram TX
Now I am confused as to what Wide and Narrow are on a TK-8180N-K2. 25khz and 12.5?
Looking at the chart of GMRS channels sorted by freq, there is only 6.25 between most of them, which would be 12.5kz bands. The ch16-ch2 gap is quite slim at 3.75khz. Sample below, FRS excluded. I'm licensed on GMRS too.
Traditionally/currently:
Wide = 25KHz wide channel, 5KHz deviation.
Narrow = 12.5KHz wide channel, 2.5KHz deviation
On the Kenwood radio, setting the channel to "W" on the far right side of the channel/zone programming screen will give you the wide channel width. N = narrow band.
Yes, but you are confusing the spacing between the individual channels with deviation. Two different things.
RenoHuskerDu
Bertram TX
Thanks, yes I was ignorant. I suspect many old-time hams still think mainly of the original 6 GMRS simplex freqs before FRS got folded in. That is the case for my local Expert, from whom I get advice and buy used equipment.
I got this list below from the FCC horse's mouth.
Channels​
There are 30 GMRS channels with a bandwidth of 25 kHz (20 KHz authorized bandwidth) or 12.5 kHz as outlined below:
ChannelAuthorized Bandwidth
462.550020 kHz
462.562520 kHz
462.575020 kHz
462.587520 kHz
462.600020 kHz
462.612520 kHz
462.625020 kHz
462.637520 kHz
462.650020 kHz
462.662520 kHz
462.675020 kHz
462.687520 kHz
462.700020 kHz
462.712520 kHz
462.725020 kHz
467.550020 kHz
467.562512.5 kHz
467.575020 kHz
467.612512.5 kHz
467.600020 kHz
467.662512.5 kHz
467.625020 kHz
467.712512.5 kHz
467.650020 kHz
467.587512.5 kHz
467.675020 kHz
467.637512.5 kHz
467.700020 kHz
467.687512.5 kHz
467.725020 kHz
