RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,378
Ok;
I have a new to me Kenwood TKR-840-1 which I plan to use on GMRS. So far I have reprogrammed it as I require. Very smooth programming.
As I received it it had been programmed near my frequency about 400 KHz higher. So I have not bothered to sweep the helicals. It seems it may be within the 5.0 MHz BW of the receiver.
My first question.
I have a carrier squelch pair in the radio (where it was previously programmed) and I wish to compare 12 dB SINAD points to my GMRS pairs which have multi tone table set. What I am finding is that the squelch is a bit tighter on the CSQ pair than where I am operating. SINAD seems close, it just wont break squelch until signal is somewhat higher
In the test mode found the analog and RSSI squelch settings in the tuner and adjusted them somewhat loose as I like it that way. However this CSQ channel seems to have some higher setting. Perhaps by design? Maybe I am missing something? Both are WB channels.
Yes I could just turn on a tone table and compare. But I want to learn something.
Second question.
The radio was set to about 3.5 W on high power. I went through the Test Mode tuning and adjusted for 5.0W high power using a known good bird wattmeter and HP8920B. I also calibrated the power meter to agree. I then attempted to set Low power to 1 watt and found that it reads on the test screen at about a fraction of a watt .1 to .2 W. When I calibrate the low power wattmeter, the high power channels read ridiculously high 27W. Is the power detector non linear??
The help screen for the power setting is written poorly and also I get a warning showing the TX ranges of the radio when I do a calibration. Not sure what that is about.
I have not opened the radio up so I am assuming all is set with soft pots.
Third question.
"Reverse Burst" seems the repeater receives it properly but when the repeater drops out, my SABER radios are not feeling the love. Looking at my HP8920B scope, the CTCSS tone is present throughout the drop out delay and there is no evidence of phase reversal or "chicken burst". Setting dropout delay to off accomplishes nothing. There are no reverse bursts heard during a conversation so squelch tail suppression by the decoder works. The radio just fails to eliminate squelch tail at the subscribers. Is this a "firmware thing"?
Lastly. How do I determine my firmware and HW version?
My first question.
Second question.
Third question.
