Kenwood TK-930 800mhz receive on 902mhz?
WX5812
Fort Worth
I have the proper software and the hacked (kenwood3.exe) software to program that into the 930 but how well will it receive in the 902mhz range?
Very poorly, if at all.
The filtering is all going to be designed/tuned for the 800MHz band. It's likely going to be deaf as a post on 900MHz.
AK9R
Staff member
Super Moderator
Central Indiana
The following website has info about using Kenwood radios on the 902 MHz amateur radio band, but I don't see the TK-930 listed:
n2mci
Kingston, NY
I have made a tk-930 work at 902. I move the freq in file saved by kpg org. I had to cut a trace that forces the VCO range so it works in the Talk Around range. As was stated, the front end filter makes rec'er deaf. You need to either change the front end filters or bypass them. I swapped the front end filters . A 3 and 4 pole filter. I know other have bypassed the filters and put a duplexer in front of the radio as the the front end filter.
So it can be done, it depends how much work you want to put In to it.
Pete N2MCI
