Kenwood TK3402UK
JustinSchmidt
How come when I transmit with my Kenwood tk3402UK and I try to receive the transmission with a baofeng, I can only get a couple of feet line of sight, before the radio can’t receive the signal?
kd4efm
Florida
Bad antenna port / connection
Need to crack it open and check the solder joint on the antenna connector on the board.
FKimble
Newnan, GA
How close are the two radios? The Baofangs front ends are pretty crappy, you may just be overloading the front end.
Frank
FKimble
Newnan, GA
Yes you are too close. The transmitting power at close range will overpower the receiving circuit of the other radio. Could even cause permanent damage especially if it was a mobile radio at full power. You can also reduce the transmit power which will help, but get 25 yards or more to test radio to radio.
Frank
