Kenwood TK372G Range Question
Steveradio
LehighValley/Poconos Pa
Will the Kenwood TK372G receive outside the 470mhz band it seems to take the frequency how ever have no way to monitor anything?
Friend of mine travels into New York and wanted to add a few of the 470mhz frequencies for when visiting family.
Just curious if it will work or not, thanks?
Starion1
Phila Metro
Kenwood TK-372G
The Kenwood TK-372 UHF portable although rated to cover frequency range 450470 MHz (Type 1) should be able to operate up to 12 MHz above and below the rated range with minimal degradation to transmit and receive. Obviously your results may vary. Keep in mind that in programming you can set programming to trick the radio to program as if it were a TK-370G and this will allow you to have the TK-372G have a total of 128 channel instead of the originally designed 32 channels.
On the used market, the model you mention (Kenwood TK-372G) is the best bang for the buck. Readily available aftermarket accessories, wide/narrowband capable, alpha-numeric display, OST (operator selected tone) which allows the user to bring up any analog tone for the pre-programmed frequency to be changed on demand. Great feature for the traveling GMRS users whose licensed on the frequencies but need to bring up a different tone.
