Kenwood TK690H will nott power up
mikedaly
Redding,Ca
i purchased off of ebay. They had nonway to test it. But this is what i have done.
1. It has a single remote head.
2. I have the power connection at 13.8 V.
3. I have the #1 pin on the 9 Pin connector powered with 13.8 volts.
4. I opened up radio and there are some resistors missing. If in the picture that are below are correct. There is no way this radio will power up.
And is there a solution to get this working.20200518_212250.jpg20200518_155950.jpg20200518_212250.jpg
sfd745
Reverend Higgy
Southern Maine
A small wad of solder across R504 and R742, and clean the other pads will give you power on, no ignition sense.
A small wad of solder across R506 and R742 will give you ignition sense.
ramal121
Lots and lots of watts
Calif Whine Country
Your picture shows a valid configuration and should power up with the ignition sense lead. As mentioned by sfd745 you could switch the jumper setting to default to see if that helps.
But while you have the cover off, check the smt fuse F502 to see if it's popped. It's toward the front of the board just behind the white connector that goes out to the control head. And you can check at this connector the line marked PS. You should see a 12v pulse when the power button is pressed.
KK6ZTE
California
You sure about that? With 504 and 506 absent and 743 absent, the book says the transceiver won't power up.
mikedaly
Redding,Ca
So here is an update on what i found. I purchased another from a different person. Still not powering up. Checked voltage. 13.8 V. So at this point im thinking its got to be something im doing wrong
My bad, for the life of me it looked like 506 was missing.
. Lets get to the basic.
Voltage check.
Brand new head. Check.
Cable 17 ft. There is the problem. Someone sold me a cut cable. I didn't see it thinking that someone would not sell me a cable that was cut and not tell me. So its time to add a crappy review on someone's Ebay account.86239
