Kenwood TK762HG-1 indicator led question.
drbeede
Gatewood,Missouri
Ok so I have a Kenwood TK762HG-1 and the led light beside the power button lights up red when you transmit and is not lit when in normal stand by, but today it is lit up green on all channels. What does it mean when the led is lit up green and stays on?
I am a lineman for the county.
Green LED means the receiver is hearing something strong enough to break carrier squelch.
If you have a QT or DQT (CTCSS/DCS) tone set on the channel, you won't hear anything through the speaker unless the code matches.
If it's happening on all of the channels, it probably means one of the following:
-The squelch is set too loose.
-There is a strong noise source nearby that is creating enough RFI to break squelch.
-Someone is transmitting on those channels.
drbeede
Gatewood,Missouri
Thank you, I know what the issue is now, I programmed the squelch too low. By the way what is a good level for the squelch? I noticed I could set it from 0-9 I was thinking of setting it to around 5 maybe that would do the trick. right now it is set to 3.
