Kenwood TK8180 issue
radio259
Pittsburgh PA
TK8180, set uyp for two tone decode with beep. 6 beeps. Worked well till last week. Now we only get one beep if lucky. No system changes, radio not set up for scan. Stays on dispatch. Old age or other issue?
Programming checked and all good there.
ramal121
Lots and lots of watts
Calif Whine Country
In your paging channel you have the optional signalling set for 2-tone <n>. In decode 2-tone <n> you specify the alert tone sequence number (beeps). The beeps are set up in Special Alert Tone. The programming is good all the way around? In Special Alert Tone what do you get with an alert test?
kd4efm
Florida
Video would help also, can you use a service monitor to test it or a portable setup to Encode the tone, with bugging dispatch?
Also show you 89DN photos of the channel and program information on your two tone. If your paranoid just blot out the channel freqs or just show the other settings minus other stuff.
a417
U+0000
if the radio legitimately wasn't touched, programming or anything, then the radio needs a date with a service manual and a trained tech.
radio259
Pittsburgh PA
Referring to tech. Has not been touched in few years, needs FCC check any way. No one has reprogrammed. As I said, worked fine then just stopped. Might be time for new radio any way.
