Kenwood TK8180H vs TK-8360H for GMRS
9Track
Hello. Have newly registered, but have been reading the forums for a while. I've not been able to find this kind of information on these two radios, but have a couple of questions that maybe someone will know.
Is the TK-8360H a newer radio than the 8180H? If so, I've wondered why it has 128 channels, whereas the 8180H has 512 channels?
Are there any advantages to one of these models over the other? I'll primarily be using it on GMRS. I have the 8360H and have been using it on GMRS, but am wondering if there is any benefit to also getting the 8180H? If I can find the H version of either model in 400-470 MHz, I may program it for GMRS, as well as some repeaters on the 70cm ham band. (Mine is 470-520 MHz.)
Thanks much,
Steve
Welcome Steve.
No, not really newer, just aimed at a slightly different market. The TK-8180 has more features/channel capacity/display size. 8360 has less, and is thus a bit cheaper.
You'll save some money on the 8360 if all you are doing is GMRS. It has less features and should be a bit cheaper, at least they were new. 8180 is going to be more popular and will probably cost you a bit more used.
If you wanted to really toe the line on the FCC rules, none of the H model radios have Part 95 acceptance, and if someone at the FCC really wanted to focus on the rules, it would not be legal to use on GMRS. But, yeah, unlikely anyone would ever notice. You would not be the first one to do it.
Kenwood did not make a 400-470MHz version of the TK-8360. They were all 450-520MHz. They might stretch down towards 440, but I'd not bet money on that. Some will, some give up before they get that far out of their design.
The TK-8180 came in two band splits:
400-470MHz
450-520MHz
They came in two power levels:
H models were 45 watts on high power
Non-H models were 30 watts on high power.
None of the 400-470MHz models had FCC Part 95 certification, again, if you wanted to really follow the rules to the maximum.
None of the H high power models had Part 95, either. But again, unless someone was holding the RF deck in their hands, they wouldn't be able to tell.
9Track
mmckenna,
Great information - thanks! Wow, that Part 95 business is an elusive category to run down. I thought they were Part 95, which is what got my interest to start with. It looks like my idea of a 45-watt UHF commercial radio that will do both GMRS, 70cm and Part 95 is difficult to find.
I also thought about a Motorola PM400, but the software appears to be much harder for me to find. I also like the Kenwoods and their menus and like that external speakers can be connected with an 1/8" plug.
Guess I'll keep looking and researching. Thanks again!
Don't get hung up on the power level. 30 watts vs. 45 watts doesn't make a big difference in range, and you can easily make up that difference with better coax or antenna gain.
9Track
I've thought about that. I may just go with the 30 watt version.
