spdfile1
/\/\ Junkie
So I'll start by listing my equipment involved. Kenwood TM-V708A Mobile Dual-Band (2M/70CM) Radio, which is hooked up via 3' RG-8X coax to an MFJ-817C SWR/Power Meter which then goes to (via another 3' RG-8x Coax) a Diamond CX-210A A/B Antenna Switch. Now the antennas I run with are a Comet CA-2x4SR Dual Band Mag Mount Omni-Directional Antenna (A side of the switch) & an Arrow II Satellite Antenna Model 146/437-10WBP Yagi (B side of the switch) both of which are inside the house in my "Man-Cave" (as I can't place any antennas outside my condo). The Omni is about 4-5 feet from the mobile & the Yagi is maybe 5-6 feet from the mobile. I also purchased a MFJ-261 Dry Dummy Load to test my radio. Everything was purchased new within the past month except the Kenwood Mobile & the Comet Mag-Mount Omni-Directional Antenna which were purchased new back in 2006 & the Arrow Yagi which is about 5 years old (roughly). Now one thing I didn't do was hook up the dummy load directly to the SWR meter (which the write up says to hook it up directly to the radio without coax, but than I can't measure power) and I used the 3' length of RG-8X to connect the radio with the dummy load. Now at low power (5 watts) it puts out that at both 2M & 70CM. At medium power (10W) it shows 10W. However at full power (50W for 2M) & (35W for 70CM) the SWR meter only shows about 25-29 watts. I'm hoping that when I connect the dummy load directly to the antenna side of the swr meter that will change but I doubt it cause I'm never that lucky. Does anyone have any idea other than the obvious what may be causing this?
Problem #2: So having the radio go thru the SWR meter and the AB switch to the mag mount (I haven't tested the yagi yet) I get high swr on 2-meter (haven't tested 440 yet). I tested in 1 MHz increments from 144MHz to 148MHz and I get @ 5W on 144MHZ about 1.8:1 swr and @ 50W about 2.25:1 swr. On 148 MHz I get about 2:1 swr on 5W & 2.5:1 on 50W. Totally unacceptable!!!!! So than I decided to cut the AB switch out and run the Mag Mount coax directly into the swr meter and what a difference.. I had swr down at 144MHZ of almost 1:1 on 5W,1.2:1 on 10W & 1.3:1 on 50W. Up on 148MHZ I think the highest was 1.5:1 on 50W. So yes my new AB switch is for some reason causing high SWR readings. That I understand but does anyone know why this may be happening other than the obvious fact that the AB switch has possibly turned to s&$t?!?!?!?
Boy getting this SWR meter has proved one thing. My equipment has a lot to be desired lol!!!!!!!
