Kenwood: Kenwood TM V71A I have
caerickson
Phoenix, Arizona
I own several TM V71A mobiles used as a base and mobiles. I'm having audio issues when listening to repeaters in my area. The audio is very basely and muffled. I have some hearing issues but I don't have the same issue when using other mobiles or portables.
Has anyone had similar issues and identified a possible solution. Any suggestions will be appreciated.p
krokus
Southeastern Michigan
Are you using the internal speaker, or external speakers? If external, which speakers? Are you using one per band, or combined audio?
caerickson
Phoenix, Arizona
I use two Motorola external speakers. One for each receiver. Both receivers are set to UHF Motorola Quantar repeaters that are wideband analog.
vagrant
ker-muhj-uhn
California
1. If the audio on other mobiles or portables sound okay using those same speakers...See #2
2. Kenwood and other brands had bad ceramic filters installed years ago for a particular batch. I believe they were the Toko filters. Anyways, I have had two or three Kenwood D710 radios that I sent back when the filters went bad. Fortunately, Kenwood repaired them for free. I just had to coordinate the return first by providing the serial number. The Kenwood repair center shipped it back on their dime. I contacted Leo Fahmie, first to coordinate/approve the return, but I am unsure if he is still with Kenwood. I believe the serial numbers for the bad V71 a were 903 to 003.
Leo Fahmie KJ6HI DM03
Amateur Radio Technical Support
Service Division / Communication Sector
JVCKENWOOD USA Corporation
Long Beach, CA 90810
kcc-amateur@us.jvckenwood.com
Hours: M ~ F 8:00 ~ 4:00 P.M. PST
Phone: (310) 639-4200 voice prompts 4, 1
The audio on my radios with the bad filters was low and crackly. I think another way I tested was to adjust the radio from wide to narrow, which cleared things up to confirm that was the issue before getting the RMA from Leo. Basically, he sent me an email which I printed and included with the radio when I sent it in. I only sent the radio and not the mic, nor the head (or faceplate) for your V71.
krokus
Have you tried other speakers? I have had one Motorola speakers sound bass, on various radios.
