Kenwood to David Clark Headsets take 2
traingeek087
Hello Group. I need some help. Several months ago I posted about wiring a Kenwood TK780H to a set of David Clark 3800 headsets. (See Link.)I followed the instructions and used them for the first time this last weekend. I had to wait that long because I don't have another radio to test them with. Unfortunately they didn't work.
Link. - > http://forums.radioreference.com/kenwood-forum/281857-kenwood-tk-760-david-clark-headsets.html
I cannot here any radio broadcasts through the headsets, and when I press the PTT button I cannot transmit. When I turn the headsets up the speaker on the radio turns up. I know the radio works because I can hear broadcasts through the radio, unfortunately I cannot make it out because of other noise. I need it through the headsets.
Can someone help me here? I don't have anywhere I can take it close by, and its all permanently mounted. It has to be a wiring issue.
Thanks,
Traingeek087
KE5MC
Lewisville, TX
I did take a quick look at the linked thread. Having done a lot of cable construction using various brands and family of connectors I can say it easy to make a mistake about connector numbering. My impression of your post is nothing is working correctly and I am thinking more than one wiring error.
Try making a detailed schematic from headset to radio. You might discovery the error during that effort. If you already have one, double check your work.
Good Luck,
Mike
ramal121
Lots and lots of watts
Calif Whine Country
Sounds screwy to me to and I can only echo to double check the wiring hookup. As long as all six wires are used from the headset cable and go to the right spots on the KCT-19 connectors, it should just plain work (except for a possible tweek to the transmit audio from the headset).
I crossed the headset wire colors to the pins on the KCT-19 connector in the previous thread. If you need a better diagram, let me know.
traingeek087
Yes, please send me a diagram. It shouldn't be that hard but a diagram would help me.
I wired the connector up the way the diagram said, but i'm wondering, was I suppose to change anything inside the radio?
Traingeek087
traingeek087
Guys, thanks for the help but unfortunately it didn't fix it. I rewired it and I can hear through the headsets, but no transmitting. When I use the hand mic it makes an aweful squealing noise in the headsets too.
I should have bought a Motorola that fits the David Clark system better. Maybe I'll sell the Kenwood and save up for a Motorola. Very disappointed with the entire thing.
Stu
