Kenwood VM5000 mobile programming question
Stonehawk
Deerfield, WI
Good morning!
I am the department programmer for a few departments, and am just starting to work on the VM-5000 series. Loving the Armada software for our VP5000 and VP6000 radios, but I have a very simple question. In previous iterations of radios, it was a simple plug and play to connect to the radios to read/write.
In trying to connect to the microUSB cable on the back of the mobiles, I get no radio connection. Is there something I am missing to be able to connect and work on these radios? I have the proper .key and .akey files and have been successfully working on our portables, but cannot seem to connect to the mobiles to even see the radios.
I am positive it is something simple, but I cannot figure it out.
Thanks for reading!
Jerry
Stonehawk
Deerfield, WI
I just upgraded to the 1.40.13.128, and also just uploaded the original codeplugs from our radio provisioner, I am thinking that might do the trick. I now see the selection option of VM5000/VM6000/VM7000. I will try it this morning.
Jerry
AlexC
If the mobile has WiFi turned on and enabled in the existing configuration you have to turn off WiFi to connect your laptop directly. Make sure there is a WIFI menu option present, it's set to a button, or you have it enabled on the softkey menu. Otherwise, it should connect. What is amazing is the VM7000 stack if you have a USB hub you can simply connect all the bricks at once and mass upgrade everything. Takes a while but it works pretty smoothly.
