Kenwood VP400/600
surfacemount
Knox / Roane / Loudon counties, Tennessee
I know zero about these.
Quick research suggests they are single band, programming by armada, that they are EOL, and parts are drying up.
Can this be used to do P25P2 NAS?
Would there be ways to add features (aren't they called entitlements) without setting up a vault account, similar to how certain moto units can get feature sets modified in the wild?
Thanks in advance,
SM
DeoVindice
P25 Underground
5150 Level
They are not capable of NAS without a system key. Purchased features can be added via a .opu file generated for the specific serial number, or Vault can be used. Vault accounts are free so there's no downside to that upgrade path unless it needs to be applied offline.
Project25_MASTR
TX-COMU
Texas
And to add, even though the first gen Viking radios are no longer supported, you should still be able to purchase features for them (because you can move features from older Viking radios to current Viking radios and vise-versa). The VP900 is the dual band model and came in VHF/7/800 or UHF/7/800. As far as the VPx00 radios go, they use the same Jedi accessory interface as the preceding 5100ES, 5100 Ascend, 51SL, XTSx500, XTS3000/5000 and the only thing that was really new is the serial interface (TTL logic on the Motorola radios, RS-232 on the 51xx) was dropped for a USB interface. The VM series are the mobiles and were built on the same chassis as the preceding 5300ES radios (and finding some of those accessory pigtails is very difficult).
They perform a NAS exactly like Motorola radios do...get a system key, configure scan (in this case it's a Radio Wide Scan List instead of a scan list within the system).
surfacemount
Oh,
I thought I had read somewhere it was a simple box check, and that made them more sure in the no-affiliate realm. Thanks!
n7maq-1
Oregon
Oh,
That is the BK radios, no key needed for RX only. What band are you interested in? I have a few BK KNG-P800 radios that I may let lose of some.
