countryguy
Hi there
I have an XTS5000 with an 8 algorithm module installed, KG1 DES-OFB KG2 DES-XL KG3 DVI-XL KG4 DVP-XL KG5 DVI-SPFL KG6 AES-256 KG7 ADP KG8 AES-GCM
OK I know that our system uses AES and DES, the radio is programmed as conventional ASTRO25 with OTAR Multikey, I have all keys stored in the radio and I can see them in the CPS, but I am having a problem when I turn the radio on it reads right away and gives a tone saying " KEY FAIL and ENC FAIL " and when I turn the knob below ch to secure TX I see a O with a line trough it but immediately I see " NO KEYSET and KEY FAIL " with a beep sound.
OK now I turn my friends radio on in same channel exact same programming and when I turn his radio on I see on the upper screen mid level it reads AES and he's radio is working fine so what the heck and to top it off he only has 3 algorithms DES-OFB DES-XL and AES-256.
The only big difference between both radios is that my radio is an XTS5000 III and his is an XTS5000 II
So in other words mine is a model 3 his is a model 2 but both have the exact same programming.
Any ideas.
Any ideas.
