Warpspeedpoop
- Joined
- Sep 25, 2022
- Messages
- 1
Hello,
I recently acquired a KFDShield and all the necessary hardware to perform keyloading on my EFJ 5100 ES radios.
I am using a Motorola NTN8613C Hirose adapter which I've gotten modified as per the recommendations in this thread.
Miraculously enough, I've managed to get to the point where plugging in everything together results in my radio displaying "Keyloader".
When performing the Self Test in the KFDtool software (the test that requires the radio not to be plugged in), it passes successfully! However, when using "Detect MR", I first get this error message:
and if I try again shortly after:
The same thing occurs when trying to "view key info" or when trying to actually load a key:
One exception to this is that I've managed to use the "view key info" once, which returned some variation of a "no keys found" message, which is encouraging. However that's only happened once after getting many error messages, and it hasn't happened again.
I'm at a loss at the moment, given the fact that "Keyloader" shows up on my radio's screen the entire time everything is connected together. Would anyone have any idea what is going wrong?
Thanks a ton
Thanks a ton
