I'm having an issue with a 70cm repeater that's programmed (using software) into my radio, so I wanted to see if everything is in there correctly. When I use the menu to look at the setting for MENU+28 (offset) or MENU+06 (shift direction), the radio won't go into that menu function. In other words, (while in memory mode) when I press menu, rotate the VFO knob to either of those menu positions and press menu again to look at or change the setting, it just exits the menu and goes back to the channel display.
Is this normal? It seems to happen on any memory channel. I realize I can see the shift direction on the display, but can't see the programmed offset via the radio. I'd have to go back and see what I set through the software. I could go into memory frequency display mode and key the radio, but I'd rather not key up just for test purposes. I'd prefer to know what frequency I'm transmitting on before I do it. Thanks.
