KNG-M150 Remote Head Speaker
EMT_20
Paris, Texas
Just installed a KNG-M150HPR and I want to run a single speaker from the auxiliary cable assembly that is connected to the radio deck and not the remote head. I can only get the speaker to work if I have it connected to the remote head. What settings should I have enabled/disabled to run the speaker from the radio deck and not the remote head?
ramal121
Lots and lots of watts
Calif Whine Country
Even though the same accessory cable is used for both the head and deck you can only get speaker through the head and on the flip side the ignition sense lead can only be used on the deck. I don't know of any way to change these.
EMT_20
Paris, Texas
Ok. Thanks. I knew about the ignition sense wire on the deck but I figured with all the audio options and accessories these radios have you would be able to wire it up any way you wanted. Oh well.
WRTL350
Oakland, CA
You can uncheck HCH Master Volume Control in RES to switch the audio output source to the deck from the head.
EMT_20
Paris, Texas
I will try that tomorrow when I get to work to confirm. I already completed the install and re-ran the speaker wires and added an accessory connector to the remote control head. I did not want to do that due to the way the RCH is mounted on the center console and I wanted to keep the clutter down since it is exposed in the passenger compartment.
WRTL350
Oakland, CA
I haven't tested it in the configuration you're using, so let me know if it does anything else besides move the output audio. I have only needed to do this when adjusting programming designed for remote head installs to run on all-in-one units.
