KNG-P800 Scan Function
policefreak
Berlin, NJ
I'm using my KNG P800 as a receive only device on a local system where there are about 10 towns on the system and every town's local FD, EMS service, and PD has their own dedicated talkgroup. Even with a few of the PDs encrypted that still leaves me about 24 talkgroups needed to monitor the whole system. Is there a way I can monitor more than 16 talkgroups on a P25 Trunk Channel knob position? I'm currently using NeoVision 2.4.0 software.
DanRollman
Atlanta, GA
There's no way to add more than 16 talkgroups to a scan list, no. I am not sure whether TG 65535 ($FFFF), which is a wildcard that monitors all talkgroups on a conventional channel, will also monitor all talkgroups on a trunked system. Might be a solution for your case if it works.
Dan
wirr
Senior Member
Instead of using Add, paste more channels into the list.
wirr
Senior Member
I'm using RES 5.5.9 currently. Bring up a Scan List, select a channel in the scan list, right click, Copy, right click, Paste Above.
DanRollman
Atlanta, GA
I will try too. Have you found a limit to this, or any drawbacks? I never really understood the reason for the 16 TG limit, which isn't unique to BK either.
Can you still edit the scan list from the radio, or does that aspect go haywire once you have more than 16 TGs in the list?
wirr
Senior Member
I haven't found a limit, but I haven't tried to.
I'm not aware of any drawbacks, but I also haven't verified that it actually scans them all.
The scan list can be edited but it is seems to be still limited to 16 channels.
So it may be that you can add more than 16 in the software but the radio doesn't actually scan them.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
While it's good to know that I'm not the only person who has wanted the ability to add more channels to my BK radio scan lists, looking at RES 5.5.9 Help topic on "P25 Trunking - Scan Lists" makes me think that the channel limit is actually 16.
