- Joined
- Feb 22, 2007
- Messages
- 5,647
Alcohol is always a good conductor, especially when you have a corroded battery compartment from leaking batteries, before you can get in there and really clean it up, it seems isopropyl alcohol always, it's a temporary fix, because it's alcohol, it evaporates,Would isopropyl alcohol, 70%, work as well?
To Inject into the encoder?
Very hard to find the part. Uniden doesn't sell it but I found the maker of the part, Tocos.
If you're going to make an attempt at my solution I would definitely go with contact cleaner, lubrication, WD-40, something more permanent.
