Kohl's At Harlem Irving Plaza?
KC9NCF
Banned
Does anyone have the radio system info for Kohl's at the Harlem Irving Plaza? Can't find it anywhere. Do they use another corporate name such as a holdings corp or something?
Astro25
Chicagoland
Search the generic business band frequencies. (anywhere from 461.x - 469.x)
Common retail frequencies are:
461.1125
464.500
464.550
467.850
467.875
469.500
469.550
They typically use a PL of 67.0, but often use a random DPL.
RADIOGUY2002
Chicago Burbs
Their is a way, however
Their is a way, however it is very time consuming. Kohls direct serach national wide which yeild a corporate division and then from their a seach by control point and county. However, seraching a set ranage will be easier or checking into a website that lists typical frequencies used nation wide. Usually their pretty acurate except for the pl / dpl code.
kevino
Database Administrator
Chicagoland
Common biz-band portable freqs
Many models of radios commonly used in retail stores (Moto XTN, CLS, etc) utilize freqs selected from a pre-programmed pool of 27 VHF and 56 UHF frequencies. You'll find a list of those common frequecies at http://www.walkytalky.com/Programming/Programming_XTN.htm . I'd start by looking at the UHF freqs, as I found sales folks at Kohls' Elmhurst store using one of the above-mentioned radios on 467.875(82.5) in August 2005. Someone on the CARMA Yahoogroup http://groups.yahoo.com/group/carmachicago/ found 466.3375 in use at their Batavia store use back in July 2005.
FWIW, I've found that stores with loss prevention officers typically utilize separate freqs for sales floor, stock room and loss prevention operations.
